Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1158 Questions View all
Cracked screen
ok...i dropped my iPhone 3gs front screen cracked and the image is just..completely white..anyway to fix this? I can still hear the buttons when u click emergency call so it works but i just...cant c anything and its cracked
Score -1
Add a comment
1 Answer
Chosen Solution
Try holding home and power for 10seconds... Screen should go black and apple will show. Release buttons and allow to reboot. If that doesn't work follow guide for front display and reconnect no1(LCD cable) if that doesn't work you'll need a new LCD. Make sure when opening iPhone that phone is powered off.. Tricky with a White display but hold power for 5-10 seconds then slide finger across upper display as if sliding to power off.
Score 2
Add a comment
Add your answer
david will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 299
