Model A1059 or A1099 / 20, 40, or 60 GB hard drive / touch sensitive click wheel
227 Questions View all
Can't hook up to Itunes
I just received my iPod back from you and everything works fine except when I plug it into my computer it won't hook up to Itunes. I get a message that says " A iPod has been detected but it could not be identified properly, please disconnect and reconnect the iPod and try again" However that doesn't work. What do I do? Thank you
Score -1
1 Comment
What do you mean "I just received my iPod back from you"?
by
Add a comment
Most Helpful Answer
More than likely a bad USB cable. This has been the case for me 90% of the time when it came to this error and I was testing various iPods and usb cables.
2nd possibility - bad dock port on the iPod itself OR bad usb port (try another?)
Some 3rd party iPod usb cables are terribly poor quality and some don't work at all. I don't normally recommend the most expensive parts for a lot of things with good reasoning, but this is an exception for sure - I highly recommend the apple-brand iPod USB cable as they have definitely had the lowest failure rate. They also have the fastest detection times with iTunes as well!
Try a different iPod USB Cable, preferably a pretty new one. No matter what brand the cable is, some definitely go bad over time or from damage such as moisture.
Score 2
Add a comment
i can not hook my ipod to itunes
Score 1
Add a comment
my ipod has been disabled and i cant hook up to itunes because my computer wont download itunes how do i do it without itunes
ipod 4th gen.
Score 1
Add a comment
Add your answer
Tom Houck will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 4
All Time: 1,436
