MacBook internal HD mounts in Target Disk Mode but not in OSX install?
Macbook Pro MId 2015 - went for a clean install after some startup issues, but The internal SDD does not mount once I get to internet Recovery and OSX install. Doesn’t mount in Disk utility either.
Once in Target disk mode the disk mounts perfectly on a 2nd identical MBP.
I bought a new SDD and the same problem persists, fine in target disk mode but I am unable to install OSX.
Any ideas?
Update (11/24/2020)
Pretty sure I have wiped it clean - disk utility - erase a Mac OS journaled, GUID
did I miss something here?
2 Comments
Which model do you have the 13" or 15"?
What is the current version of macOS on your system and what are you trying to install?
by Dan
15"
Had Catalina and all was well, I have an identical MPB which runs Catalina too.
The SDD is now completely wiped, as I thought that was the way to go. before wiping it mounted fine in Target Disk mode, as it does now - but If Igo to install Catalina (or previous OSX's) the SSD doesnt show on in install.
by james alexandrou
