Apple's 2016 revision to their laptop lineup targeted at professional users. Features a 15-inch, 2880-by-1800 Retina display, quad-core Intel Core i7, 256 GB / 512 GB /1 TB / 2TB storage options, 16 GB RAM, and a keyboard equipped with a Touch Bar. Released November 2016. Features Model A1707.
3rd time display failure
I have a display problem here.
It’s been sent three times to Apple technical support and my problem still continue, Apple technical support tells me problem is a software problem!
Has anybody saw this problem before?
thanks your comment
Add a comment
1 Answer
Sadly, its time to visit the Apple Store (not an authorized reseller) one more time! This time with your service paperwork in hand, talk with the service manger that you need your system fixed, and this is NOT a software issue its a problem with this given system and you want a replacement.
They will likely say No! But don’t give up! Speak with the store manager and then the regional managers (Service and retail).
If you don’t have an Apple Store near you you’ll need to call Apple and have your issue escalated. Don’t accept No! Keep pushing.
You also need to clean your system! A dirty system says you don’t treat it as a valuable item to you. And the person servicing your system we care less! Which you don’t want.
As to why your screen is failing. It’s likely overheating! I would install a good thermal monitoring app to watch things. I use TG Pro as it offers what you need.
Make sure you don’t block the vents on the side and back as not air flow will do you in! You will want to see if what you are running (doing) is pushing your system too hard. Apple (and Intel) did you a disservice with the design of this system as the CPU runs hot! And the location of the T-CON logic is too close to the heat so it gets cooked!
Add a comment
Add your answer
can İnce will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 8
All Time: 97
