Here's what's up... The stereo "pairing" between say, two Flip 6s using "Partyboost", happens between the speakers (two channel stereo). In other words, music is sent to a speaker, and the firmware of that speaker determines which channel it plays and which channel is sent to its partner speaker (both channels are not the same).
Having both speakers paired up in Bluetooth settings sends the same data to each speaker, each of which attempts to do its part by playing one channel and sending the other to its partner speaker... And the result is a choppy, horrible sounding mish-mash of the two. The speakers were not designed to receive and process the same data... One is the pitcher, and the other is the catcher, so to speak. It doesn't matter which one is which as long as one speaker pitches and one speaker catches.
The solution is to "forget" one of the speakers in your Bluetooth settings, and allow the firmware of your speakers to perform the separation and playing of stereo channels, by using the specialized buttons on whatever speakers you're using to connect to each other. Those buttons are essentially telling one speaker it's the pitcher, and the other is the catcher. The app does the same thing.
Where JBL has dropped the ball is in the implementation of the firmware. It should prevent BOTH Bluetooth speakers from performing the same role but instead seems to encourage it, making it impossible for what would be otherwise impressive software to do what it was designed to do.
Hope this helps, because once you get through it, the sound quality and performance of these speakers in stereo is nothing short of amazing.
6 Comments
Have you tried connecting it to a different device?
by Brooks Codr
Several. Not the issue.
by Charles Rieken
For me, it only seems to happen when I have my identical Flip 4 speakers in Stereo mode, using the JBL app for Iphone SE. Hadnt used stereo mode in some time and when I went to use it today, I got a message to update. I updated both speakers, rebooted the phone and the speakers and still getting speaker interruption of mixed duration after 10 minutes or so of playing just fine. Several times, the JBL app said “trying to find devices”. Strange to me, when just minutes ago, it had found both, identified them by color and was playing fine in stero.
I have not tried doing factory reset yet. I am on the latest iphone IOS. There are no other bluetooth devices in range for the phone to connect to. I will keep you posted.
by tim farnham
OK, so I am apparently stupid and i own it. BOTH speakers apparently had to be fully charged.
However, I cannot discount that my wifi connection went down in this mess. I charged the speakers while I rebooted the modem and then the router. Sorry, but who now knows where the problem lies, My guess... it was the the speakers being marginally charged.
Best wishes.
by tim farnham
Your phone is not compatible. I have the same phone A21 I'm going to switch.
by GEORGIA SNELL
Show 1 more comment
