Microsoft's third-generation Xbox game console, released November 22, 2013.
XB1 E100 code during startup
I am continuously getting this same error code. Anyone have an idea if it's fixable?
I've tried the restart, reset without deleting saves, and even factory reset, also the flash drive offline update so at this point I'll try ANYTHING. Please help?
Score 1
Add a comment
1 Answer
I don’t have an xbox myself, but I found an old post on this website with the same issue, the comment that fixed it talked about doing a reset, but since you tried that, there is another comment with a suggestion below, I would give that a try.
“If you are still having this issue I just fixed mine. I removed the hdd from the xbox and hooked it up to my pc. Accessed the system update 1 partition and deleted all the files and reinstalled the hdd. Then took a flash drive (any drive over 8gb will work) and formatted that to NTFS and extracted OSU1 to it and inserted it into the USB port on the xbox. Booting the xbox by holding for 15 seconds, the bind button on the side and the eject button and pressing the power button. The console then fully went through with the system update. Afterwards i just had to redo the initial setup but all my games and saves were still there. Hope this helps someone else. “
Add a comment
Add your answer
donaldrb1989 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 21
All Time: 1,424
