Shop the Holiday Gift Guide
Computers that generally don't include an integrated display, and are meant to be stationary.
Microphone doesn't pick up voice, but rather computer audio
everytime i use a mic, instead of taking the audio of my voice and using that, it takes the audio of the computer and uses that. its any mic
Update (11/08/2020)
The computer im using is a different computer, its a desktop pc with no microphone built in, i have a headset that has two plugs, a mic and a headphone one and they both plug into the front of the pc
5 Comments
Hi @QualityPotato 99
Is the computer that you’re connecting the mic to a HP EliteBook X360 1020 G2 by any chance?
Are you using a standalone mic or a mic attached to headphones?
by
What is the make and model number of the computer and what OS is installed?
by
its a custom built pc
by
@QualityPotato 99
Posting the motherboard make and model number and the installed OS version will help us to help you.
by
windows 10 home
gigabyte ultra durable 970a-d3p
by
Add a comment
1 Answer
Chosen Solution
Hi,
Some things to check:
Has using the microphone via the front panel connection ever worked OK?
If not, do you know what the PC case, front panel audio module type is?
It could be either a HD audio or an AC’97 type module. The reason I ask is that they are connected differently to the motherboard and the settings are set to HD audio by default.
See p.26 of the motherboard user manual for how the audio panel is actually connected to the motherboard connector and on p.71 how to configure the audio for the 2 different audio types available.
If you have an AC’97 audio module then on p.72 Sect. C it details how to activate the AC’97 front panel audio.
From p.74 onwards it shows how to set the microphone settings which may also be of some help.
Score 1
Add a comment
Add your answer
QualityPotato 99 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 15
All Time: 207
