iPhone 4 powers off after lcd replacement
I just replaced an iphone 4 lcd, it worked fine and now when i power it on. i can use it for like 3/10 minutes and then i see an fastly white screen and it crashes/shuts down.
What could be the problem or how could i fix this?
Kind Regards.
4 Comments
Can you make sure the battery connector isnt damage at all? The shutting down thing sounds like a battery problem. The white screen sounds like an LCD problem. If you have the old screen, try putting that in to see if it does the same thing. Report back with what you find.
by hectordtruong
Thanks for the reply, well the other lcd i got has no digitizer so i can't use that one! and i have no idea how to battery could be broken, i got an video of the crash:
http://www.youtube.com/watch?v=SLBCkCiSZ...
by Gijs
Oke just replaced the old digitizer, and it also crashes what else could be the problem?
by Gijs
Also when i remove the battery while i have it in the usb loader it also crashes after some time.
by Gijs
