How to repair my backlight led
So my tv's backlight stopped working and when I checked the backlight LED strip, I saw that it used a 310mm long strip with 56 LEDs; four sets of 14 LEDS, running in parallel at 12V(I think). Since, it's an old tv and the replacement strip is nowhere to be found online, I was wondering if I can use one of those universal CCFL to LED conversion kits like this; https://www.ebay.com/itm/353141213143
and then just take the led strip; ignoring the driver board and just solder it to the 12v and ground of my tv's led strip connector and cut off the other 3 parallel circuits. Would this work? As I know nothing will be controlling the brightness of the led strip except the voltage. But it is an edge lit display so again, don’t know if that will be an issue
Note; I also measured the power source of the leds on my tv's power board and at the strip's input connecter and I got 12v output, so I think that board is good however what is weird is I'm not sure where the problem is exactly, as all 56 leds do work when I test them in pairs with my multi meter just not with the tv's full 12V.
Pictures; http://imgur.com/a/9hLsWaa
