Sony XBR-75X850E No video, audio works, backlight works
I've got a fun one… I’ve factory reset the tv (power + volume down) and when powering on I can hear the setup music. Tv dims and gets brighter when pressing buttons but there is no video, just backlight. Usually when turning it on after plugging it in it will only stay on for 5 sec then turn off and flash red 5x. Hitting the power button to turn on again will result in tv staying on but still no video.
I have replacement boards for the video board, power board, and t con. I have swapped all in and out 1 at a time and nothing seems to resolve the issue. It’s possible parts are bad but unlikely imo. Nothing get’s worse, its the same each time. Could it be another board somewhere else in the tv?
I contacted sony support but they were unable to send me the link to the service manual (could not find a link that would work for me outside of their network) and diagnosed as likely a faulty "G” board but were unable to tell me which that may be (seems to be power from a little googling)
I’ve read through a ton of things on here for others tvs but nothing has helped me pin down the issue unfortunately. Tcon board fuse has continuity and meters 12.7vdc when powered on. I tested original power board voltages (cannot remember what they were) but will gladly do so again if anyone knows what to check?
I assume the tcon feeds a board for each half of the display, seems weird if those boards both went bad somehow.
Appreciate any suggestions or help!!!
1 Comment
Sony XBR-85X850g
please i also have a problem with my sony 85x850g tv it start up normal and off after 24 sec by itself and restart again and do the same thing again. Please i need your help.
by moses mohammed
