Released September 22, 2017. Model A1864, A1897. Available as GSM or CDMA, 64 or 256 GB Storage Options, and the color options are gold, silver, and space gray.
678 Questions View all
iPhone 8 plus not charging, but wireless charging after housing swap
Hi, i did a housing swap for my iPhone 8 plus, and everything seems fine, but i can’t get it to charge with the charger wired, wirelessly it charges fine but when i plug it in it doesn’t charge. when the phone is ran out of battery and i plug it in the battery icon shows its charging, and if the phones off with battery and i plug it in, the apple logo shows but i can’t get it to show as charging without wireless charging when its actually on. can anyone help? thank you!
Score 1
Add a comment
Most Helpful Answer
So what most likely is your issue, is that you damaged the charge port its self, it can be replaced but thats what your issue is to my knowledge. another way you can check too see if that is the issue check the microphone and see if that works and if the loud speakers work, if neither of them work as well with the charging then you need to get a charging port replacement
Score 1
Add a comment
Was that backhousing a new one with preinstalled dockconnector? Otherwise take out your old dockconnector and try that one,
2 Comments:
ive tried different dock connectors and still the same issue!
by
take a look at your logic board especially around the battery connector maybe a small component was knock of?
by
Add a comment
Add your answer
lewis will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 7
All Time: 256
