A new version of the Galaxy Tab A 10.1 was announced in February 2019, with Android 9.0 Pie (upgradable to Android 10), the Exynos 7904 chipset and an IPS display with an unchanged resolution. The rear flash is removed, S-Pen support is dropped and the battery is smaller, while the front camera is upgraded to 5 MP and the speakers are now stereo. Models numbers: SM-T515 & SM-T510.
42 Questions View all
When I do my lockscreen, it says try again in 30 seconds what do I do
Hello. I have a samsung tablet that does not work right now. I draw my pattern on my lockscreen and it says "try again in 30 seconds" and I'm not sure what to do i'm typing the right password and I'm currently typing this from a computer. Is there any way you could help?
Score 4
2 Comments
Do u solution already
I this problem today
by
Power off then power on
by
Add a comment
Most Helpful Answer
You could try restarting the tablet or performing a factory reset. If you can’t get in the tablet the procedure to factory reset is as follows:
https://www.verizon.com/support/knowledg...
Score 4
2 Comments:
I hv done it nothing hppen
Volume up + power
My screen on sleep
by
@ujaejang Power off your tablet first, then do volume up+ power.
by
Add a comment
I just simply restarted it, and everything went back to normal.
Add a comment
Add your answer
Atenea Estulin will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 32
All Time: 6,704
