“Three Beeps” Memory slot problem.
I have upgraded my CPU from i5 to i7 and my hard disk 1 TB HDD to 2 TB SSD, all the job was done by myself and I was extremely careful not to brake anything, however after I finished the upgrade and try to start my iMac the screen didn’t turn on and I hear a steady "3 beeps" every few seconds, NOTING that when I worked on the motherboard I didn’t even touch or replace the memories sticks at all because I already had the max RAM for my iMac module .
My iMac details:-
iMac 27-inch 5k (Late 2014)
Intel Core i7-4790K Quad-core (4 Core) 4 GHz Processor - Socket H3 LGA-1150 Pack CM8064601710501(after the upgrade)
Storage Samsung 860 EVO 2 TB SSD (after the upgrade)
Memory 4 sticks Sk-Hynix 1600 MHz DDR3 each 8GB total is 32 GB (now with the issue I have only 16 GB that mean 2 sticks out of 4 is working.
Graphics AMD Radeon R9 M290X 2 GB
OS Catalina Version 10.15.7
And after all of the attempts I have made to solve this issue I found that the first 2 top RAM slots aren’t working while all the memory sticks are working fine, so I am using now only 2 memory sticks total 16 GB inserted in the 2 bottom slots and the iMac is running fine.
Here is some of my attempts after figuring out the slot issue:-
- I try to posh the memory sticks hard to the top slot (Didn’t work)
- I try to start the iMac with the 2 memory sticks placed on the 2 bottom slots then I shut down the iMac and replaced them on the top slots (didn’t worked)
- I try to use 2 sticks in different slot like 1lot 1 & 3 or 2 & 4 (didn’t worked)
- I try to used only one memory stick in the first top slot (didn’t worked)
- I try to used only one memory stick in the 2nd top slot (didn’t worked)
Can someone help please to fix this issue with the first 2 slots from top.
2 Comments
What was the specs of the i7 CPU you put in?
by Dan
@danj
by Ehab
