The Kenmore Elite HE3 is a washing machine by Kenmore.
669 Questions View all
Won't spin and drain in the spin cycle?
Our washer Kenmore Elite He3 Model # 110.44832 200
run a normal cycle until it gets to the "spin" cycle, then it won't drain and spin. I have looked at other answers in the blog and have cleaned all hoses and filter trap....still wont work. What next???
Score -1
Add a comment
Chosen Solution
Cheryl, iif it won't drain check this items according to the Service Manual from here
1. Check Wire Harness connections.
2. Check Drain pump.
3. Check Drain pump motor.
4. Check that the Drain hose and Drain Pump Filter is clear of
foreign objects.
5. Check the CCU.
Page 52 of the same manual tells you how to run a diagnostics. See what error code you gt on your washer. Of course when you get to the drain pump (available here) check the inlet and outlet for missing socks ;-) etc. sometimes you will find the weirdest things in there. Not a whole lot of pulleys on this machine, all motors and CCU's ;-) let us know how it is going, good luck.
Score 3
2 Comments:
+ nice research
by
thank you Sir, hope you are doing alright....:-)
by
Add a comment
Most Helpful Answer
If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
Score 4
Add a comment
Add your answer
Cheryl will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 4,555
