rear left brake light and blinker not working
my rear left brake light and blinker will not work. I have replace bulbs and fuses. Any idea on what to try next?
Angie Womack, check to see if you get power to your light assembly. I have had an assembly with a broken connector from the harness to the assembly, it had the same issues. Use a multimeter to check for current to your contacts.
UPDATE
or just a cheap simple testlight from corner hardware store.....;-))
As a side note, you can also check potential (voltage) if you only have a playing old boring voltmeter :)
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 659
