Repairs for a broad range of sound-generating equipment including speakers, sound bars, and speaker components.
Tronsmart mega not charging
Bought in 2018, I love this speaker. However last week the battery was low, so I plugged a charger cable in. The MODE light lit up red continuously and I thought it was charging. However it soon went completely flat. Whenever I plug the charger in, the MODE light is steady red, and after a while goes into flashing red. But no charge. Any answers? Thank you
Score 2
1 Comment
I have similar problem as well. The red light keep on blinking without. Right now the it is not coming on any longer even when connected to power source.
by
Add a comment
Chosen Solution
denis beedi this” Whenever I plug the charger in, the MODE light is steady red, and after a while goes into flashing red” sounds like it does what it supposed to d. It appears as if you are having issues with the battery not taking a charge. I suggest you replace it and then re-evaluate. With that you would at least have a known-well starting point for further troubleshooting.
Score 1
Add a comment
The real cause is dying battery. The good thing - battery in these speakers is made from two 18650 Li-Ion cells, connected in series with 2S BMS/balance board. Pretty easy to make a new battery from good 18650 cells, especially if you have working spot welder. But you can solder a new battery, from fresh 18650 cells in series, using a solder with low melting point. Use original 2S BMS board and connect cells to the board in same spots..
Score 1
4 Comments:
yup, can confirm that this is the solution. Prying out the the solder tabs and soldering back without a spot welder is a bit tedious work but manageable. the battery holders are very convenient and allow some room for a sloppy solder job.
one thing tho, there are 4x18650 batteries connected as two parallel pairs in series (sorry if that doesn't make sense technically but i hope you can tell what i mean lol).
by
UPDATE: Nope, i take it back. The batteries i removed seem to be doing ok and it might have been the charging port all along bc right now it's not charging consistently even though i replaced all of the batteries and the charging port is actually very loose.
by
Another update: The charging port does seem to be the issue. More specifically, the barrel seemed like it slightly caved in from the seam. I used a toothpick to push up a bit and close the gap at the seam. Looks like it helped and it's charging/drawing power from the adapter now.
by
Where do I purchase a adapter for a tronsmart speaker
by
Add a comment
Add your answer
denis beedie will be eternally grateful.
Past 24 Hours: 10
Past 7 Days: 32
Past 30 Days: 101
All Time: 6,394
