Help with iPhone 8 not responding nor powering on
I've got an iPhone 8 that worked fine, it had no issues with booting, running or charging. The screen was slightly cracked and the glass on the back case. It was dropped. But like I said everything ran fine for a long time.
I ordered a new screen original and the back housing. (The back housing I ordered was with all small parts and components but they later messaged me it was out of stock so I said cool just send me the housing and I'll transfer all the small parts over). So the back housing came and I transferred everything over. When I went to boot up the phone to turn it on it went into boot loop. Turned it off, re checked everything and found the very small flex plug which I believe is the Antenna flex to be broken. (I have attached a photo of it so you can see which one I'm talking about).
After trying to turn the phone on again it did not respond or turn on. I found it strange that one second its in boot loop and next second its unresponsive. So I measured the voltage in the battery, was fine 4.13 v. I tried plugging power into the charging port and neither did the charging logo appear on the screen. Nothing at all.
So I'm thinking:
1- Screen cant be dead cause it just worked.
2- Tried plugging it into itunes encase screen was dead but phone was on (that was not the case itunes did not detect it so phone was off).
3- Battery is fine as tested with multi-meter.
I have tested all the pins by known good readings for the J6400.
Most where fine apart for these which I found a bit high.
Pin 6 - 0.802
Pin 8 - 0.802
Pin 20 - 0.805
Pin 22 - 0.802
Pin 24 - 0.802
Pin 25 - 0.721
Pin 26 - 0.907
Pin 27 - 0.721
Pin 39 - 0.612
Pin 41 - 0.612
(All diode readings)
And maybe 50, 53, 54 and 56 (all at 2.32) is a bit high what do you think?
From your experience by the readings I provided do you think there is an issue with the U2700 power IC? Or could it be an issue with the original charging port when it was removed and put back into new housing??
What I have done is ordered a new housing with all small elements already installed. If that does not resolve the issue will try replacing the power IC. I know that it regulates power to the phone and also charging, so if the phone is unresponsive it could be due to this.
Please let me know your opinion on all this.
I appreciate it.
Update (09/27/2020)
Here is the picture I forgot to post
2 Comments
The picture is not attached...
by Minho
I've added the photo
by Tommy Duris
