Upgraded HDD to SSD not won't work reliably
HELP!
I have quite a similar problem. I upgraded my MBP 13" mid 2012 with a Samsung 250gb 860 EVO 2.5" SSD. I've done tons of research before I proceeded changing my MBP drive with an SSD. However, my macbook is acting wierd with the SSD but not with the HDD.
my problem is:
- when I turn on my macbook, halfway through the bootup loading screen it shows a "Prohibitory sign" ( which means a valid start-up disk has not yet been found), after a few minutes the screen shuts off then turns on and displays the loading screen and continues to complete the bootup. After the bootup is complete it takes few minutes to load up the mac OS interface and Once I'm on the mac OS interface everything is so slow and sluggish, whenever I moved my mouse or even open a folder or anything my cursor keeps on turning into a colorful spinning wheel.
I have tried:
- tried cloning the factory drive to the SSD using Carbon Copy and I have reset PRAM..
- tried installing a fresh copy of Mac OS from a USB stick and external hard drive.
-tried creating an external bootable drive by installing the Mac OS on the SSD using SATA to USB cable
-tried system preferences and set Startup Disk setting to be SSD
Note:
The SSD is working fine, I tried it on my sisters MBP 13" mid 2012 and it was working perfectly fine.
I also, tried booting up my mac with the external bootable SSD drive using SATA to USB cable and it works perfectly fine. However, when I install the SSD on the mac the problem occurs again. So, I was thinking it could be the sata cable. Next, I tried using a different hard drive and also tested my sisters MBP hard drive on my mac and it boot up just fine.
My findings was that my MBP doesn't like the SSD but works well with any other HDD.
I have not tried using a different SSD,
I have not tried changing the sata cable yet.
What could be the problem?
-tried the SSD on my sisters MBP 13" mid 2012 and it work perfectly fine.
and tried all possible way I could think off. I tried the
6 Comments
Were you able to resolve this issue? I have the same problem and after tons of research, many say the issue is a faulty SATA cable. I'm currently waiting on the cable to be delivered from Amazon.
by T M
boot the Mac Holding Command + S, once the commands have stopped popping up on the screen and you can type, type the following thats in quotes but don't include the quotes "fsck -fy" note you may have to run this command more then once, I had to run it 3 times before the output command said that it mounted the drive correctly, it also sped up my SSD
by shane4web
Were you able to resolve this issue? I am experiencing the same challenge after installing an SSD.
by Kyle c
@kc2 - Please review my answer as I've fixed 100's yes that many! by replacing the cable and properly installing it.
It is such a big issue I won't upgrade a drive unless I replace the cable!
by DanJ
@danj After reviewing your answer, I got a replacement SATA cable (the 2nd one I've replaced), and that did the trick in resolving the issue. Thanks!
by Kyle c
Show 1 more comment
