MacBook only turns on if I connect the magsafe holding Power on buttom
Hi everyone, I have a problem with my macbook pro mid 2009
I´ve been using a non original battery
It worked fine until a few days ago when the macbook never turned on again with the battery.
Only turns on if I follow some steps
With no battery connected, I have to plug in the magsafe while i´m holding power buttom
Keyboard backlight off and cooler fan working at full speed.
Then if I turn off my computer, I can turn it on again only pressing power buttom one time.
If I disconnect the magsafe I have to repeat again the process to make it work again
If I plug the battery while the computer is working, automatically will turns in to power safe mode and only works if I disconnect everything and the process to turn on again is the same.
But!!! If I try to turn on with battery connected, it will never turn on!!! and when i disconnect the battery the computer turns on by itself!! with no power buttom
I´ve heard something about SMC system, so I tried to reset a few times, but i think that could be the SMC chip.
Any ideas???
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Adding images to an existing question
by Dan
