The slim edition of the classic Xbox 360 with a 250GB HDD and built-in Wi-Fi. Repair requires intricate prying and special tools.
307 Questions View all
Very bad corrosion everywhere!
Ok Guys I have had my Xbox for years now. But recently when I opened it up there was a little corrosion around the heat sink. At first, I believed it to be nothing so I wiped it off with some rubbing alcohol and put it back together. Now today when I opened it. It's EVERYWHERE. It got on the heatsink, board, even the metal chassis! what do I do I’ve cleaned it off at least 3 times and it comes back every time worse than before? HELP i dont think the dish washer trick will work with the xbox D:
1 Comment:
Bobby Gunnels post some pictures of what this all looks like with your QUESTION. Adding images to an existing question
Do you have your Xbox in a high humidity environment?
by
Add a comment
1 Answer
Corrosion is usually caused by humidity, acid buildup, or decay. When it comes to batteries, corrosion is usually taken care of with a solution of baking soda and water. However, you do not want to put water into your Xbox. The safest way to clean it off is to avoid liquid period. Use baking soda and a toothbrush to remove what corrosion you can and then cover all metal surfaces with dielectric grease. It is not electrically conductive and will protect anything metal from moisture and acid. Just don't go crazy and cover the entire PCB in grease. A little bit goes a long way. Just a very thin coat should do. Dielectric grease can be purchased at any automotive shop or online for fairly cheap.
Add a comment
Add your answer
Bobby Gunnels will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 8
Past 30 Days: 11
All Time: 275
