Model A1502 / 2.6 GHz (Turbo Boost up to 3.1 GHz) or 2.8 GHz (Turbo Boost up to 3.3 GHz) dual-core Intel Core i7 processor with 4MB shared L3 cache.
494 Questions View all
Changed battery and keyboard/trackpad inoperative.
I see someone else had this problem back in 2019 and it was suggested the trackpad needed replacement. What would cause this with just a battery change? Is there anything else that would cause this to happen? How can I definitely be sure it’s the trackpad and not something else? Is there a troubleshooting procedure or is it a matter of changing it and hoping for the best?
follow up question re: this posting. are the keyboard and track pad somehow connected together so that a damaged trackpad will cause the keyboard to stop functioning also? found a damaged cable on trackpad( got a bit too aggressive removing the battery) that explains the trackpad being inoperative but not sure how or if that is the whole problem. any suggestions?
Score 1
Add a comment
1 Answer
Most Helpful Answer
Inspect the keyboard cable and the trackpad cable for damage. It’s possible these were scraped during the removal of the embedded battery. If you see any damage here this is most likely the cause of your issue. If just the trackpad cable is damaged and the keyboard is still non functional there might be an additional issue. If the keyboard cable is damaged you will most likely need to replace the top case which can be a pain. Alternatively you can disconnect the internal keyboard and use a wired external or Bluetooth keyboard instead. In the attached photos the red circle shows the location of the trackpad cable and the yellow circle shows the location of the keyboard cable. Hope this is helpful!
Score 2
2 Comments:
not sure how this works re: accepting or rejecting an answer. I appreciate your comments and suggestions. I did damage the track pad cable but didn't understand how this could affect the keyboard since neither are working now. I did a diagnostic and did not get an indication there was anything wrong with either device, only that it did not detect a battery. computer is noticeably slower now too. it is not happy. did an OS reinstall and still have the same problems and the same diagnostic result. no battery detected. hard to believe removing a battery could cause so much trouble. may get another track pad and plug it in without a complete install and see if anything changes.or I may have to just deep six this thing ,lick my wounds and chalk the whole thing up to a learning experience. not sure yet if I want to throw in the towel but am leaning heavily in that direction.
by
If all else fails I would recheck the connections on both keypad and tracpad, disconnecting and reconnecting each one. It also sounds like the battery has a bad connection. Try disconnecting and reconnecting it and see if that helps. If none of that works then you may have a bad logic board. I hope its just a bad connection.
Best of luck.
Eddie
by
Add a comment
Add your answer
Bob Rittner will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 59
