Released September 22, 2017. Model A1864, A1897. Available as GSM or CDMA, 64 or 256 GB Storage Options, and the color options are gold, silver, and space gray.
678 Questions View all
Bottom left of screen turned grey/black after the screen replacement
I bought a cheaper iphone8 plus with shattered screen . I was hoping to fix the screen and start using it. I replaced the broken screen with the new one. When I turned on the phone, the bottom left of the screen turned greyish/black. I thought that it must have been the circuit problem. I uninstalled the screen and reinstalled it but it still the same. Old screen didn’t have that issue. What could be the problem. Please help. Thanks
Add a comment
1 Answer
Do you still have the old screen at hands? connect the old cracked one again and see if that has the same problem. If the old one works fine you simply got a bad display from your supplier, unless you damaged it during the repair.
1 Comment:
No I do not unfortunately. I threw it away. I don’t think that the display has gone wrong. I installed another Logic board in the phone using the same display and it works fine. Could it be the motherboard?
by
Add a comment
Add your answer
shanparshan will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 4
All Time: 95
