Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Questions View all
Question Closed
No service, low signal after replacing backplate
I bought a rear plate, i repleaced it carefully as mentioned, but after that, my internet is gone, low signal, or even no service. I put back the original one, but the problem is still on. :( I was very careful.
Thanks
Add a comment
There is an antenna behind that backplate, check if you have damaged it as its very fragile
1 Comment:
What you mean behind? On the other side of the backplate, or on the iPhone's back? I checked the everything, but everythings seems to be ok, but as i said, i was really careful and not playing any parts of it just changed, but after changed back its still bad:S
by
Add a comment
the service sticker attached to the speaker unit has a small diode that needs to be reconnected.
1 Comment:
reconnected to the motherboard.
by
Add a comment
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 3
All Time: 941
