Why is my microwave making a hissing sound when plugged in?
My microwave fuse blew when I opened the door to interrupt the cycle. After some googling, I decided to replace the switches and the fuse. I got all the correct replacement parts. After I put everything back and plugged it in, it started to make a strange hissing sound. Any ideas why?
3 Comments
The connection is loose or improper check them once again
by Sanjeev Kumar
Checked so many times and it’s still making the noise. The sound is high pitched and almost inaudible.
by Boomer200
I’ve had a quick look into this, and it seems that the part that is causing the loud noise is called the magnetron tube. This part is what is responsible for cooking/heating whatever is in the microwave, using electromagnetic waves. If the magnetron tube is burning out or failing, it will often create a loud high pitch sound, as the frequencies being produced are higher than what they should be. If you want it fixed, you’ll have to get a professional out to replace it.
by Esa Rashid
