Early 2011 Model: A1278 / 2.3 GHz i5 or 2.7 GHz i7 processor
782 Questions View all
Does not go to sleep when lid is closed
Hello,
After replacing the battery on this computer, the computer does not go to sleep when the lid is closed. Everything else works fine. Maybe it is a damaged hall effect sensor?. What would most likely have been damaged in the process of replacing the battery that would have caused this? How would I go about fixing it?
Thanks!
Add a comment
1 Answer
Hi there,
Is the display setting set to always on?
1 Comment:
No. No software settings were changed after the battery was changed, including the display settings. It used to go to sleep before.
by
Add a comment
Add your answer
Albert Einstein will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 4
All Time: 50
