Released November 4, 2017. Model A1865, A1901. Available as GSM or CDMA / 64 or 256 GB / Silver or Space Gray. (Pronounced the same as "iPhone 10.")
1199 Questions View all
iPhone X screen replacement cables TOO LONG?
Hey.
I hope someone can help me because I have been stuck for days.
My iPhone X needed a screen repair, so I bought a so called OEM screen.
this OEM screen has longer cables, But Also thicccer cables that the original screen. When I was assembling the screen, part of the folded cable stuck out from the iPhones frame, and it still does. I really need help on how I can keep the cable from sticking out, because I cant fit the screen correctly.
Any answers are highly appreciated
thankk yu
Add a comment
Most Helpful Answer
If you look beside the mother board on the power button side there will be a little space where the cables can curl down and sit in there.
Score 1
1 Comment:
thanks man you saved my day
by
Add a comment
The bottom cables can slide under the screen. Do ut slowly.
Add a comment
Add your answer
Ted Olsen will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 3
All Time: 72
