Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
Question mark folder at start
My unit will give a “? in a folder” symbol at startup. Removed and connected hard drive externally and unit boots up and operates fine. Ordered and installed a new cable that connects hard drive to logic board. Same problem; “? in a folder symbol”. Ran hardware test on startup and it is OK. Need some help please.
Add a comment
1 Answer
Most Helpful Answer
Your systems PRAM setting is messed up! So your system doesn’t know which port your boot drive is located.
With your drive properly in place restart your system and Press the Option (⌥)  to gain access to the Startup Manager, select your internal drive and you should now be booting up under it. We still need to get this firmly set still. Go to your System Preferences > Startup Disk, unlock the setting select your drive and then hit the Restart button. That should fix things.
Reference: Mac startup key combinations
If it doesn’t then the replacement cable is bad or damaged.
Did you reformat the drive and install a fresh OS onto it? Many a time the data on your drive is not clean because of the bad cable. I would first make a full backup using TimeMachine then redo the drive and restore your stuff back.
Score 1
2 Comments:
The drive works fine when connected externally but is not recognized when connected with internal SATA cable.
by
That points to a bad HD SATA cable! MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable
Your Hard Drive Cable Is A Ticking Time Bomb Besides the cable its self and adding the electricians tape, the way you handle the cable is also important as many people damage it just trying to put it in.
Find an old BIC pen to take the empty ink straw out as you'll want to use it to help you form the bends. The cable's arc can't exceed the radius of the straw where you need to bend it. Folding/creasing the cable damages it!
by
Add a comment
Add your answer
Terry Chapman will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 64
