Xbox loses HDMI signal while running and is no longer detectable
So I ended up with my sister’s old Xbox One bc they couldn't get it to work and the family cat peed on it. I managed to get it working after disassembling it and generally cleaning everything the first time. It worked for about 2 hours, visuals and audio shut off and went to a no signal screen, and wouldn't come back on again. Took it apart again, deep cleaned everything including the fan, motherboard, and lightly the heat sink with 91% isopropyl (light corrosion on the metal rungs) then 5% acidity vinegar on the metal panels on the places it was severely corroded and rusted under the heat sink from the pee (thankfully nothing on the motherboard or important bits besides the bottom of the xclip). Managed to get it booted up and staying on for about 5-10 minutes before it did the same thing.
I've tried different TVs, different cords, cleaning out the port with compressed air, and just letting it sit for a while unplugged but nothing seems to work. I also tried looking up different guides and searching forums but so far I haven't found anything that works. It still powers on, there just isn't any signal as far as I can tell. I can't tell if the port on the console is damaged somehow (tho everything looks ok) or if it's something else.
Also as a side note, since the second cleaning, on some startups while trying to figure out the visual issue, the fan will run super hard for a few seconds and sounds like a rocket taking off before slowing back down to regular speeds. Also can't find anything on that. At this point I'm honestly just tempted to go trade it in at Gamestop since everything is clean and it works beyond that, but I still want to try and fix it. Any help or advice would be super appreciated.
EDIT: Pictures of the port, where its soldered on, and the model number of the motherboard
