Guides and support for various television (TV) brands and styles.
9058 Questions View all
How to tell if TV backlight inverter or backlight array is broken
sharp LC50LB481U
The TV originally led would flash and not turn on but I did a factory reset and now it turns and has an image if a flashlight is shone at the screen. I'm trying to figure out if it is the backlight array or the backlight inverter is there a way to test and see if it is one or the other. the parts to repair both are pretty expensive and don't want to have to buy both if only one is broken
Add a comment
1 Answer
https://www.shopjimmy.com/sid-gj2c-led-t...
plenty of videos on how to test leds. this tool will help. can find them cheaper online and more videos on how to test without removing the strips on you tube. easier than testing inverters.
Add a comment
Add your answer
11908649 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 288
