Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
2690 Questions View all
iPhone 6s keeps lagging and freezing
Hi,
My iPhone 6s keeps lagging and freezing and literally have no idea what is causing it, I originally thought a battery replacement would be an easy fix but it wasn't. I've tried resetting it and restoring and it still won't work. I can't even set it up properly without it glitching back to the start or the previous step. Everything else works normally though and I also tried a screen replacement and that didn't work either.
Please help. Any advice will be appreciated
Add a comment
Try resetting your iPhone. It must help.
1 Comment:
I've already tried that, and even worse it takes way longer than usual to boot up.
by
Add a comment
How is your home button and other buttons are they working properly?
2 Comments:
Yes all the buttons work but their actions are delayed, for example Siri is slow to come out
by
Try to boot up your iPhone without home button flex connected at the screen, if the phone boot up faster then there is a fault in the home button, if that doesn’t help try to disconnect back cam, if that doesn’t speed up boot proces the last thing you can try is to boot up without front cam
by
Add a comment
Add your answer
Daniel Gyabaah will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 2
All Time: 48
