Can you install the macOS Catalina Patcher with a hard drive
Can I install macOS Catalina patcher with a hard drive that is in a external bay or do I need a external hard drive or USB?
You really can’t run Catalina on this series. Its not worth the effort!
Remember this series can have limited RAM (2.26GHZ - 8 GB or 2.4 GHz - 16 GB). Also you can’t run older 16 or 32 bit apps which you likely have.
Lets say you had an i-series CPU for the sake of argument - Booting up your system, from which ever drive is controlled by using the Boot Manager by pressing the Option (⌥) key when you startup your system.
References:
You theoretically could run Catalina on this MacBook but I really wouldn’t advise you to. It still has a Core 2 Duo and it’s just not worth it to get Catalina on with faults when High Sierra works perfectly fine on these MacBooks.
I still use High Sierra unfortunately since that’s the maximum version my iMac supports, but chances are it’s still good for the next 5 years or so.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 7
All Time: 544
