Repair guides and support for your Toshiba TV.
193 Questions View all
picture but no sound
I have a 49 in Toshiba tv in which I just replaced the main board bc at first the sound went out and then the picture. So I replaced the main board and the picture has returned but still no sound. The model number is 49L310U. I also switched TVs when this one went out so I know the cable receiver works. What can I do next
Add a comment
1 Answer
Hi @lismitty ,
Just verifying that you've checked the sound settings, mute, volume, TV speaker off etc?
Are you using the internal TV speakers or an external sound system?
If TV speakers, is there audio from the headphone socket on the TV?
Can you try connecting to an external audio system via optical audio cable to check if it may be a TV speaker problem
Have you tried getting audio by connecting the signal input to the component video/audio inputs in lieu of the coax (or HDMI) if possible? Only suggest this as component video/audio is an analogue signal and doesn’t use the digital signal processor on the mainboard as would a digital signal from the co-ax or HDMI
Have you tried a full reset? Go to Menu > Installation > Reset the TV.
If all still no good it may be the mainboard is faulty unless the TV has a separate audio amp board.
Add a comment
Add your answer
Michelle Smith will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 7
Past 30 Days: 15
All Time: 493
