I want to detach the scanner of my Epson sx535wd and use it on its own
Hi everyone,
I’m not sure how many people have had my same idea or actually tried it, but I guess it’s worth a shot.
I have had an Epson Stylus sx535wd for quite a few years, however the printer doesn’t work anymore. It’s not a big deal, we have a few printers at home, however the built-in scanner still works and does so quite well I’d say.
I would love to salvage the scanner and its functionality before throwing away the rest of the printer, however I’m having some issue.
After taking everything apart I tried to turn on the unit with only the scanner attached, and I’m greeted by the generic error “Your printer has a problem, turn it off and on again” or something along those lines.
I then tried to connect all of the printer components and turning it back on, and indeed this time aroud it does work. However, the printer won’t let me access any of the functionalities until I change the cyan cartridge - I don’t really want to do this, since I’m not interested in the printer itself.
Is there a way to get around all of these checks and just access the scanner functionality of the unit? I really don’t want to throw away a perfectly good scanner just because Epson implemented software checks to not let me do anything with my own product if I decide I don’t want to buy ink anymore.
The issue, I fear, is that even if I were to change the cartridge and get past this check, I still wouldn’t be able to disconnect all of the printer components and use the scanner alone.
Any help would be greatly appreciated! I really don’t want to create e-waste when the product works just fine!
1 Comment
I have the same model printer which came up with the "Ink pad at end of service life" message so the printer cannot be navigated from it's screen to do anything with the scanner.
However, I have found that you can plug it into any laptop/PC and it will connect. After you have downloaded all the necessary drivers and software you can access the Epson scan software and commence scanning to take advantage of its high quality 2,400 DPI x 2,400 DPI scanner.
Apart from it taking a little more space there's no need to separate the scanner from the rest of the printer.
by Hassan M
