This is the device page for the Samsung Galaxy J7. The OS that comes stock to the device is Android OS v5.1.
170 Questions View all
Why does my phone Keep losing memory .
Why does my Samsung galaxy j7 keep losing memory , even though i remove apps n pictures
Add a comment
Chosen Solution
It hits a point that you can't put anything else in. If you look at something on the internet it ads memory. I finally had to get something with more memory. I went from 16gb to 128gb. You should upgrade to the a10e or the a50 if you are looking for budget phones. I bought a Galaxy s10 plus for 300 dollars because the guy needed money. It even came with an otterbox case. It was in excellent condition. I hope that helps.
Add a comment
It seems you got the solution from fellow members,
Anyway, the first thing that you will need to do in this case is to check what apps are using the most storage space.
For Android Nougat -
From any Home screen, tap the Apps icon.
  • Tap Settings > Device maintenance.
  • Tap Storage.
  • View the Available space value.
For Android Marshmallow -
  • From any Home screen, tap the Apps icon.
  • Tap Settings.
  • Tap Storage.
You can clear the cache and data of the app or group of apps that are using up too much space. You can also opt to uninstall them if you are not really using them.
You should also clear out some data on your phone by performing the following steps.
  • Delete unnecessary text messages and picture messages
  • Transfer pictures and media to a computer to remove them from the phone memory
  • Clear the browser cache, cookies, or history
  • Clear Facebook app cache
  • Delete call logs
In case the out of storage error message still appears then you should proceed with the additional troubleshooting steps listed below.
  • Wipe the cache partition of the phone from the recovery mode.
  • Backup your phone data then do a factory reset.
Add a comment
Add your answer
Debbie will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 9
All Time: 1,277
