Released September 22, 2017. Model A1864, A1897. Available as GSM or CDMA, 64 or 256 GB Storage Options, and the color options are gold, silver, and space gray.
water damage indicator checking
hello for all wish you all nice day please can you tell how I can know if my iphone 8 plus has water damage i see some topics saying from the sim try slot and other said from motherboard can you please tell me how i can know using both methods ???
note : I attached an 8 plus motherboard tell me please where is the indicator
4 Comments
Can you take a close up picture of the top left side of the board were the antennas connect please
by
And a picture of the other side of the board
by
@barriphone finally some one reply I was waiting since 10 hours this picture is just for information I want to know how I can determine if it has water damage or not please explain the method for me sir
by
You need to take the board out and physical inspect it for corrosion. Check and see if it's been wet. Was water inside the phone. Pull off the black coveralls and check under them. The water Mark's don't really mean anything. If you have high humidity it can cause them to turn red. The only way to tell in to physical inspect it.
by
Add a comment
1 Answer
Most Helpful Answer
the only way to really determine water damage is to open the phone and look at the LCI.
if you take a look at your picture of the motherboard you posted, see the square at the upper left. look at the thin part of the board where this connects. there is a white oval just above a flex connector. that's the LCI. if it contacts liquid, it will turn red.
Score 1
Add a comment
Add your answer
tamer will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 24
All Time: 231
