The Nintendo 2DS is a handheld gaming device developed as an entry level version of the Nintendo 3DS with nearly identical hardware, but without the 3D upper screen function.
My 2ds doesn't charge
Hi guys, a friend of mine gave me his old 2ds that does not turn on, i thought it would be a problem with the power connector. But, using a multimeter i can see that the 4.6 volts reach the pins that go to the motherboard from the back of the connector. I charged the battery with an external adapter and the console works correctly, could someone help me to check any of the components that may be damaged? Or do you know where I can get a point-to-point guide to know where the motherboard should have voltage? Thanks!
Score 1
Add a comment
1 Answer
Most Helpful Answer
There are two fuses on the board. One right next to the charging port and one beside/half underneath the wifi module. Marked F1 and F2. Some people say it's a shot filter coil (the square block next to the port with four pins), others say it's a broken charging IC.
Does your charging light come on for a short time or isn't it showing anything at all?
I have the same problem right now.. There is voltage on the fuses and on the charging pins but it doesn't want to charge the battery..
Score 1
1 Comment:
Did u guys solved? i hace same... and i have another that CHARGES but it doesnt turn on at all (neither blue led)
by
Add a comment
Add your answer
er307_sp will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 22
All Time: 290
