Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2397 Questions View all
Signal drop and keeps losing service "No Service"
I'm facing this signal problem similar to other users. It turns to "searching..." for reception and becomes "No Service" quite often under normal usage. It does re-gain full bar signal when the 3G mode is switched on, and then subsequently repeat the routine. If the 3G mode is switched off, when signal drops to "Searching..." and "No Service" status, the signal will not come back again at all, which means I have to switch the 3G back on in order to get the reception! I have asked other users on apple.com and I first thought there must something to do with the firmware version. It appears no improvement at all even after I updated the firmware version to 4.3.5 (since 4.3.4 was speculated having the key contribute to the signal problems). I'm confused whether it is firmware related problem or hardware faulty? HELP, PLS!
Score 5
2 Comments
if you have any warranty left I'd contact apple.
by
hello
i had the same problem. my phone is the 6 plus and i just need to push on the upper corner while it restart to have the reception back. I heard this is because the plus is slightly bending.
try this . it works for me even though i need to do this once in a while
by
Add a comment
Most Helpful Answer
FW was definitely not the issue. Have you ever taken the phone apart? Regardless I'm thinking that your lower antenna connector has come loose or is not fully seated. I would suggest completing STEPS 1-11 of the Logic Board Install.
iPhone 4 Logic Board Replacement
You can skip steps 6-10 and step 11 will show you the connector I'm talking about.
Score 4
1 Comment:
tnQ so much... very very helpfull and fixed my problem.....
by
Add a comment
you can replace it with a new blue iphone coil that will fix the problem
you can buy a new blue coil here for the repair
Score 2
Add a comment
I fixed my problem by following this guide here http://www.unlockboot.com/2015/10/fix-si...
Score 2
Add a comment
I checked everything, but after changing the backplate to a transparent one, i have very low signal or nothing. I put back the original and still no improvements.
Thanks
Add a comment
http://www.myibroke.com/blue-inductor-mo... is a swervice that we offer to fix this problem. its an easy fix for us
Add a comment
I have the simplest solution here http://applenewsro.blogspot.ro/
Add a comment
I honestly can't find a way to fix my Unlocked iphone 4 (gsm) tmobile
From dropping signal I can't ever find a fix been looking for DAYS PLEASE HELP
Add a comment
Try taking the SIM card out and putting it back in. Had a similar issue on an iPhone 5 and that fixed it right away.
Add a comment
Let me help you. If you you some data plan from your carrier which assigns different n/w capability for different data type (2G/GPRS, 3G, LTE). So, once your 3G data pack is over, the network goes to 2G mode which the iPhone is not able to connect to. So Head to Settings>Mobile Data>Voice & Data>Change according to your situation
Add a comment
Add your answer
Kefu Pan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 13
All Time: 60,501
