Model A1502 / 2.6 GHz (Turbo Boost up to 3.1 GHz) or 2.8 GHz (Turbo Boost up to 3.3 GHz) dual-core Intel Core i7 processor with 4MB shared L3 cache.
How to attach battery
I have bought a new replacement battery from iFixit two months ago and I’ve replaced it. Unfortunately with the heat the adhesive is gone and I have a battery that is moving inside my MBP 13. Is there a way to solve this? I’m noticing that the battery drain quickly, now it’s at 87.9% of total, but it have only two monts of life and 100 loadcycle. Can. i fix this issue?
UPDATE
As requested this is a screen from CoconutBattery. Before the problem I had an 87.9% now as I wrote in a comment, the battery isn’t recognized anymore. Already tried to reset the SMC!
2 Comments
First lets get a better idea on whats happening with your battery. Install this gem of an App CoconutBattery With the MagSafe charger plugged in take a snapshot of the apps main window and post it here so we can see Adding images to an existing question
by
I Use Coconut battery since the early 2015 when I bought the macbook. Before this problem the battery healt status was of 87.9% ! After some checkings I've discovered that maybe the battery connector is gone, it smeels of burned but there isn't any burn sign on the connector! I get the ptt001 code with the hardware diagnostic, maybe I need to replace the battery or the connector/logic board... The magsafe still locked on the orange light. My fortune is that the macbook works fine, I need it for my jobs, but I hope that replace only the battery solve the issue :(
by
Add a comment
1 Answer
Chosen Solution
There is a few things you can try to reactivate the adhesive. First you’ll need to take the battery out carefully cleaning the uppercase of any residual adhesive Use something like Goof Off afterwards you’ll need to clean off the Goof Off as well as it leaves a film using 85% or better isopropyl alcohol.
If the adhesive is not damaged with junk you can use ethanol to reactivate. Take a paper towel with is wet and wipe across the pads lightly to just moisten the surface while still wet place the battery back in.
The other approach is to fully remove the adhesive using the Goof Off and then applying the larger strips of Precut Adesive Card (getting two cards using the larger strips) or 8mm Tesa 61395 Tape
But before you remount the battery let’s make sure the battery is good.
Update (06/28/2020)
OK, looking at CoconutBattery we can see the battery is not able to supply any data to your SMC logic within the logic board. So for starters you do need a new battery! Contact the iFixit store to get the exchange iFixit Customer Support
As far as your logic board, you’ll need to take it out to inspect the MagSafe connector on the other side as well as the SMC logic for damage. Follow this guide MacBook Pro 13" Retina Display Mid 2014 Logic Board Replacement and take some detailed pictures so we can see whats damaged posting them here for us to see.
Custom cut rolls of Tesa 61395 double-sided tape for repair. Image
Product
Tesa 61395 Tape
$8.95
Score 1
3 Comments:
I need to try,thanks for the suggestion! But the connector of the battery is fault,smells of burn and I think that it's happened a sort of contact and the battery isn't detected and not recharge anymore. I Need to replace it, can you confirm me that the battery connector is the one that is removable from the slot attached on the logic board?
by
I don't know if iFix it will replace the battery with another one, I have bought it on april :(! For the SMC and magsafe connector, I don't think there is a problem with them, anyway I will take a look to the guide, but they works fine I'm sure about this, otherwise with the battery that didn't work and the magsafe connector broken, I wasn't able to power on the macbook. ?
by
@danj unfortunately I've tested the smc with the old battery and the magsafe light stay green, this because that battery capacity is at 0%! My battery is faulty, I've contacted the ifixit support and I hope thay will change the faulty one with a new one. Thanks for the help!
by
Add a comment
Add your answer
B1P will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 18
All Time: 115
