Is it possible to repair middle button operation?
The middle button of the click whee is not responding. Is it possible to repair it without replacing the entire front plate?
You will have to disassemble it. Check the micro switch on the logic board right under the middle button. Make sure it has a click feel to it. If it seems to feel like the other ones, I would start by replacing the click wheel. Also make sure the middle button makes good contact with the switch. this guide shows you how to remove the logic board. the click wheel is right under it....Good Luck
Thanks very much. I'll give it a try.
you are welcome and let us know how it is going. If you need more help, just ask..;-)
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 725
