Black and silver single cup coffee maker with water reservoir on the left hand side. K40/K45.
98 Questions View all
How to make it brew Proper Cup size
I have a Keurig K-Elite, it does not look like the picture, but this is the model I have (https://www.amazon.com/Keurig-K-Elite-St...) and no matter what, I can not get it to brew over 8 oz.
The K Elite has five cup sizes, the 10 oz, and 12 oz will only ever brew 8 oz.
I have cleaned descaled, done all kinds of things to fix it.
I wonder is there is a part that I could replace like the air pump that would fix this, or is it a circuit board problem.
Is there a way to diagnose exactly what failed inside the keurig?
2 Comments:
this is 2023 and i have the same problem. at least keurig is consistent. HAHA
by
@syfgqtlv63fo3uq check on my answer on here Cup is not getting full This can definitely cause the low amount of water.
No.More.Keurig.
by
Add a comment
Are you sure you fill the reservoir to the proper amount for the task?
1 Comment:
Yeah, It has a 75 oz reservoir tank, that I fill up.
by
Add a comment
@laurenwatson just to answer for clarification sake. I'd start looking for common obstruction in the water flow. This seems to be an issue with the Keurig Single Serve Coffeemaker Brewing System. After a while it appears as if scale build-up or other contaminants prevent the Keurig from brewing full 12oz. It takes longer to brew, the Keurig becomes louder and it dispense on the average 4oz or less. This is a "quick and dirty" guide
Add a comment
Add your answer
LaurenWatson will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 18
Past 30 Days: 45
All Time: 221
