Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
Blue screen after attempted digitizer replacement...
I have attempted a replacement for the screen on an old iPad mini, now everything works it’s just the LCD only displays a blue screen at varying brightness instead of what it’s supposed to display. I haven’t glued down the digitizer yet.
here is an image of the broken screen:
https://gyazo.com/ef1e5435e78848e821f949...
Add a comment
1 Answer
Did you disconnect the battery when you disconnected the LCD/digitizer? I would disconnect the LCD and make sure the connector is not damaged and clean it with a qtip and alcohol and a soft brush. Then try it. MAKE SURE TO DISCONNECT THE BATTERY FIRST.
2 Comments:
I'm pretty sure I disconnected the battery before the LCD, but ill try this anyway and see if anything changes
by
This didn’t work for me
by
Add a comment
Add your answer
Leaked 57 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 83
