Released November 4, 2017. Model A1865, A1901. Available as GSM or CDMA / 64 or 256 GB / Silver or Space Gray. (Pronounced the same as "iPhone 10.")
1181 Questions View all
iPhone X not charging after battery replacement
I successfully replaced my battery with ifixit battery. When i turned it on it was at around 50%. I drained the battery to 10% then tried charging it, i saw the charging icon then left it alone. I checked back on it after an hour and it’s still at 10%. I used an original ipad charger i bought from an apple store with the cable tha came with my iphone x. I also tried using my iphone 11 pro max charger and cable and still does the same. How do i fix this. Thanks in advance
Update (06/19/2020)
Fixed it! I guess I got a bad replacement battery, contacted ifixit and they sent me another one. Replaced it again and so far it works great
Score 3
Add a comment
1 Answer
Try the old battery and see if it works then. It's a possibility that you got a defective battery. You can also try unhooking the battery and letting it reset. There is a very small possibility that you have a bad tristar ic and it could stop it from charging.
2 Comments:
Unfortunately, i have disposed of the battery. Now, i have tried unhooking the battery and hooked it back it in but it’s still not charging
by
Allan is correct, most likely your battery is defect.
by
Add a comment
Add your answer
William Chua will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 32
All Time: 2,264
