Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2376 Questions View all
after installing new battery, still does not charge fully.
everything is done correctly, the battery is still draining quickly, will not fully charge to 100% and reboots alot. any one know how to fix this or know what the poblem is .
Score -1
Add a comment
Most Helpful Answer
Check the battery connectors in the logic board they tent to go bad if you pull it the wrong way.It sounds one of the coper pins are loose. if not did you got a Chinese battery for $2.00 of ebay? ;-)
Score 1
Add a comment
I'm having a similar issue. I changed mine out today and now my battery reads at 45% and to be honest it took 2/3 times putting the battery in and out before it even worked. The first few times it kept starting and shutting off.
Add a comment
Add your answer
chris will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 520
