Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1158 Questions View all
I can call only with handsfree voice system
Hi
I had to change glass of my iphone and when I closed all speaker don't work.
- with integrated speaker I can't ear and mic doesn't work
- with earphones with mic I can ear but mic doesn't work
- with handsfree it work all
- with aux car plugged it work all (not with handsfree ...)
I changed all front block (only lcd is original) but still doesn't work.
Any suggestion?!
Thanks a lot
Score -1
Add a comment
1 Answer
Chosen Solution
I would check the #3 ribbon first of all, and see if that helps the ear speaker. That is usually the culprit. As for the mic, you could have damaged it when you opened it, but that's pretty difficult. You can change out the dock and that would replace the mic.
iPhone 3GS Proximity Sensor Ribbon Replacement
1 Comment:
I tryed to put off and put in the ribbon 3 because i think it's too distant from the white line but still doesn't work.
The mic when i'm talking with handsfree it works...so i don't need to replace it ... Or i'm saying wrong?!
Thx
by
Add a comment
Add your answer
Alex Perrone will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 2
All Time: 956
