Released September 22, 2017. Model A1864, A1897. Available as GSM or CDMA, 64 or 256 GB Storage Options, and the color options are gold, silver, and space gray.
678 Questions View all
Rear camera and flashlight problem
Hello. My problem looks like this. When I turn on the camera application, a black screen appears when using the rear camera when it is set to 1x zoom, when I switch to 2x, the image appears but is blurred. I will add that the flashlight does not work either. Everything is ok with the front camera. Any solutions? Thanks
Add a comment
1 Answer
The short answer for you is that Camera and Flash Hardware work together if one has a problem the another one will fail. The blurred problem on 2x is because your phone has two cameras one has dust or is bad. I’m pretty sure that changing your rear camera will fix all your issues.
People with the same Problem:
Rear Camera & Flashlight Not Working
Why is my rear camera and flashlight not working after screen replace
Rear camera and flashlight not working after replacing battery
Add a comment
Add your answer
Jacob will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 856
