Shop the Holiday Gift Guide
Repair Guides for HP Desktops.
Boot device not found
I have tried to factory reset my computer and something has been corrupted. Now, I keep getting a screen that says boot device not found. I have gone into the Bios and have had no luck trying to locate my usb. HDD or Remote Server are my only options. I have tried just about everything. Any ideas?
Add a comment
1 Answer
Chosen Solution
Hi
What is the model number of the desktop?
Are you trying to boot from a USB recovery drive?
Try enabling Legacy USB (or CSM - not sure which setting is applicable as you didn't give a model number) and then check if you can select the USB as the 1st boot option save the changes , insert the USB and restart the desktop.
If it boots from the USB recovery drive, go to Troubleshoot > Advanced > Startup repair and check if you can restore the startup so that it boots from the HDD.
If you have Win 10 installed, a recovery USB can be created from any known working Win 10 computer. In the host PC go to Control panel > Recovery > create a recovery drive and follow the prompts. You will need a 8GB USB stick and about 40-60 minutes of time to create the recovery USB.
Add a comment
Add your answer
Miles will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 8
All Time: 198
