The screen flicker and with double image
My Mac book pro have developed a problem in which the screen starts to flicker and it gets worst progressively. It starts with couple of glitches and flicker and it progress to having two or more image of whatever on your screen flickering vertically and if I let it continue further the screen goes blank.
It’s been a while I have started to notice this problem. However I have been trying to find out what exactly triggers it. For a while I suspected a certain application start it, but now Im almost sure that it’s has something to do with the system temperature. If you have the system running without any specific app running and specially if its charging after 1-2 hour start to happen and the only solution is to close the lid and let it a be for 20- 30 minutes and it will give you another 2 hour to work with, The sooner I start using the computer the sooner flicker starts.
I hope someone can help me with this issue.
Update (05/31/2020)
As requested I have attached the video.
This I would say is at 60 -70 % bad it can get. From here become so bad that you can’t read anything on screen any more.
3 Comments
Can you post some pics or vid so we have a better idea what you are seeing Adding images to an existing question
by Dan
Hi. I have the exact same problem. How did you solve the problem?
by Deo Carlo Llamas
@Deo Carlo Llamas - Review the answer below if you have then exact same diagnostic process outcome then you too need a new display!
by Dan
