A1708/EMC 3164 — Released June 2017, this entry-level MacBook Pro retains its traditional function keys (as opposed to the OLED Touch Bar).
563 Questions View all
Power adaptor card short circuit
I cleaned up my power adapter and the cable with a weak solution of vinegar with a cotton swab unfortunately when I plugged it failed to charge then I used the second slot and it is charging very well.
I took my laptop to the service provider they said I need to change the logic board what options I have please advice it will be expensive option in India.
Thank You
Narayanan Lakshmanan India
Add a comment
1 Answer
Chosen Solution
I think the only solution I can recommend here is to see if cleaning the connector pins again by first removing the logic board so you can get to the surfaces without getting things damaged more.
I fear the solution you used wicked up into the connectors where the connector bar is mounted on the logic board. With the logic board removed, clean the foam (carefully remove it) as Vinegar is a conductive liquid. In the humid air of India it will cause issues!
  • I would never use anything other than pure distilled water (Not tap, well or spring water! As they will contain minerals which you don’t want) Even still I would mostly use 85% or better isopropyl alcohol to clean the area as it will soak up the water as its a drier for the water if needed.
Now with the logic board out use a pressurized can of 85% or better isopropyl alcohol to spray the connector area to hopefully push out the remaining vinegar solution thats in the connector bar.
As an example I use this one TRUE POWER RECHARGEABLE SPRAYER which I load up with either isopropyl alcohol or just air alone!
Will that fix the connector I’m not sure! You may need to look at the contacts to see if they are damaged. Sadly this series would require a new logic board as the connectors are part of the logic board.
Score 2
4 Comments:
To procure all these materials will take some time in India,meanwhile till I sort out this issue I can proceed charging my laptop with second slot.Thank you very much for the wonderful solution.Is it possible to attach an external card with multiple slots.Please guide me
by
I would hold off on that! Vinegar is an ionizer! So applying voltage across the wet surface will damage the part! Even the connector that is working could die!
by
I have completed the operation as per your advice and it is working beautifully well.Thank you once again for the guidance I am indebted to you for a sizable saving.
by
If you're set don't forget to accept the answer! Enjoy your reclaimed system.
by
Add a comment
Add your answer
N LAKSHMANAN Chettiar will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 5
All Time: 482
