Repair guides and support for your LG TV.
1342 Questions View all
My TV is turning off a few seconds after start up
the title says it all, I’m trying to fix up an old LG 47SL80 flat screen TV but after it turns on, a few seconds later it turns back off. I think it might be my power supply board (it’s a model EAY58470001 REV 1.0 47SL80-UA) but when I opened up the TV I saw no issues, I’ve already tried cleaning it and that’s not working either. Do I need to replace the power board? Is there something else I need to do? Something I can fix on the board itself? Need help.
Score 1
Add a comment
Most Helpful Answer
@blamman before you go all willy-nilly replacing random boards, I suggest you try some troubleshooting first. You need to check your power supply and measure the outputs to the main board and the backlight LED’s etc. Your TV may turn off because of issues on those other boards. sure it is possible that this is the power board but it may also be something totally unrelated. LG is a bit odd and a few even turn off if there is not response from the backlight or the T-con board. So, get multimeter and measure the voltages. You can try and disconnect the main board from the power board and see if it stays on. Measure stby voltage etc.
You also want to repost your pictures with some that have no motion artifact and proper lighting. It is impossible to see things clearly on the ones you have posted.
Score 1
2 Comments:
I'm trying to find the pins you are talking about but the only ones I found are the GT501-509 are those the measuring pins you are talking about?
by
Measure the pins on the components listed. Like P800, L803 etc. You images are not clean enough to point out where to test.
by
Add a comment
Look there if any wire is damaged or cut.and touching the other side of panel.in my case there was so I repaired it.and also note your board number and find similar board like it on internet and try to differentiate them.
Add a comment
Add your answer
Xan Argo will be eternally grateful.
Past 24 Hours: 5
Past 7 Days: 12
Past 30 Days: 55
All Time: 4,793
