Keyboard and trackpad not working
I was using my computer, took a break to do something else, and went to open it back up and suddenly the trackpad was very delayed and and keyboard wasn’t working so I reset it (using the power button) and now the trackpads not working at all along with the keyboard
I tried to troubleshoot it and attempted to do a SMC reset but any time I click/hold the power button it turns on right away and I can’t go through all of the steps for that.
the thing is is that whenever I try to move the trackpad or push a key the blinker for the type indication delays as if it’s taking a second to process something and then doesn’t (other wise it blinks at a regular consistent speed). Also after a bit it’ll tell me there’s no keyboard connected and nothing happens.
I don’t think it’s directly related but I’m gonna mention it just in case it could be. A week ago I did replace the battery using a kit I bought on here. Expect the thing is is I haven’t had any issue relating to the keyboard or the mouse since the issue earlier today already mentioned so I don’t think it has anything to do with that. Seen below is photo of battery data but I’m pretty sure that’s installed fine I just mentioned it as a passable cause.
Update (05/19/2020)
This image came up and from what I got from it is that I need to bring it to apple to fix stuff. Slightly related to this point will apple take my MacBook if I tried to fix it on my own because as I said I did replace the battery and I know some companies say you’re on your own after that
3 Comments
See if you can use either a USB or Bluetooth keyboard and mouse to get control over your system. You'll likely need to check the battery using this gem of an app CoconutBattery take a snapshot of the apps window and post it here Adding images to an existing question
by Dan
Okay using a mouse and a keyboard I was able to log into the computer and use it. Note it is also acting much slower then normal. I update it and then after that I check if their was a virus and there’s still no response from the built in keyboard or the trackpad. I checked the battery health and it says it’s fine but I attached the photo anyways. What should I try next to fix it?
by Lexie
Good! Lets see if we can run the onboard diagnostics. Restart the system and press the D key to enter. Did you get any errors?
by Dan
